Old 09-14-2009   #11
Re: wont start
An engine needs 3 things to run: Fuel, spark, and compression. Generally at the opertune moments help. Get a spark plug test or take a plug wire off and place it close to a good ground (not the fuel rail) and watch for spark. Then take a small screw driver or similar and hold it onto the injector, you should feel it pulsing while cranking. Check the CAPs in the ECU, check the power transistor, check the coils, check the coolant temp sensor, make sure the MAS is pluged in, check for thrust bearing wear, could have taken out the crank shaft sensor.
