Old 09-18-2009   #14
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: I want switch to e85, smart people click please
When you talk about Fuel map are you talking about your VE table?
I think AEM is MAP...
Anyway if it is a huge map like that, leave that map alone and change another setting. You don't want to change those settings because you are tuning for VE. So those numbers you want correct. Otherwise if you take it to a tuner they will be kind of confused
When I am tuning on my Standalone (which is not an AEM so you will have to search around), there is a box in the general inputs that ask me
Engine Displacement
Number of Cylinders
Injector Flow
Air Fuel Ratio
And that gets me my Required fuel in (ms)
I just change my AirFuelRatio to what I want it which I think is 9.7
And BAM! works
Then I can tell what my actual (close to it anyway) VE is
if this is completely different because of AEM then ignore this
*I am running a WIX fuel filter
what clogged on mine is the screen on the pump. Make sure to change that!
