Old 11-15-2009   #8
Re: recurring brake rotor problem...
Ok how are you feeling the pulsation? Is it in the pedal, or on the steering wheel?
Rear brake pulsation usually is felt in the pedal, while front is felt in the steering wheel. It is typically amplified as speed increases.
I will assume you are talking about the front. Are you sure the steering and suspension components are good? IE Wheel bearings, tie rods, ball joints?
