Old 12-13-2009   #2
CarPsyco84
CarPsyco84's Avatar
Re: 1g starter wiring
The one with the right angle connector which should have a red rubber boot goes on the open stud on the Solenoid (The positive +), the other one goes through one of the bolts used to bolt in the Starter(The ground -). You should be able to trace back the positive wire right back to the battery post.
-When in doubt, Moar RPM.
