Old 02-06-2010   #23
Eurotrash
Drives: 92 Laser RS
Re: Strange mis-fire problem
Originally Posted by CarPsyco84 View Post
Is the Ecu stock? Alpha's car did something similar with a 1g maf in it, when he put the 3g one it came with back in it ran perfect... Whatever maf you use, the ecu has to be setup to work right with it. Just because it dies when you unplug it doesn't mean the maf is good, they can fail at higher airflows only.
The car has an Eprom ECU, ive been hearing that the stock MAF doesnt work with this??
Eurotrash is offline   Reply With Quote
