Old 02-09-2010   #11
b00sted_spyder
Re: Spyder in the making
Here goes the mod list.
Engine:
6 bolt 4g63 block
-.020 Ross pistons
-Eagle rods with ARP bolts
-standard crank
-Clevite 77 bearings
-ARP headstuds
-Oil pump
-BSE kit
1g head
1g intake manifold
Non-turbo throttle body
3g lifters
BC 280 cams
BC valve springs and retainers
New OEM 6 bolt timing belt kit
New OEM water pump
New OEM 90 oil filter housing
Topline complete gasket kit
ARP mainstuds
Cometic MLS head gasket
Forced Performance Exhaust Manifold Stud & Nut Kit
EGR block off plate
FIAV block off plate
Coil on plug
Non-cruise control throttle body cable
90 Oil cooler setup
Intercooler support bar
Jay's racing alternator relocation kit
Lower timing belt cover(GVR4)
6 bolt swap harness
New OEM Thermostat
New OEM Engine mount bolts
Drivetrain:
FWD transmission
B&M short shifter
New OEM transmission bolt
Competition Stage 4 Clutch
New OEM Flywheel inspection plate
New OEM Starter plate
New OEM Clutch cylinder reservoir
New OEM Clutch cylinder reservoir bracket
New OEM Transmission mount bolt
New OEM Transmission mount nut
New OEM Rear mount bolt
New OEM Rear mount nut
New OEM Front mount bolt
New OEM Front mount nut
New OEM Fulcrum clutch pivot bolt
New OEM Clutch release fork
Turbo system:
Ebay 3" intercooler kit
Fuel:
New OEM Fuel filter
Suspension:
H&R 15mm spacers
H&R extended wheel studs
KYB GR2 shocks - 50.00
New OEM(6)Top strut mount bolts
New OEM(2)Suspension fork bolt
New OEM(2)Suspension fork nut
Wheels:
2GB 17" GSX wheels
2GB 17" AWD Talon wheels
Brakes:
AEM 4 piston and 12" rotors
New OEM Master cylinder reservoir
New OEM Master cylinder reservoir bracket
Body:
OEM fenders
RM front lip
Interior:
Quick release and hub
Steering wheel
Total: $6361.97
