Old 03-09-2010   #11
Re: Progress since last year
Originally Posted by santa View Post
Wohoo! I was trying to get your attention!! I think the .58 is gonna make that turbo hit real hard! Do you think my old style tial 38mm gate will control it ok?
Worst case with the exhaust housing, you just buy a .68 T4 for $200.
The 38mm might be able to control it, depends on the exhaust manifold design and WG placement. If you are only going to run highish boost anyways, then it should be fine. The problem is when people try to run them on pump gas with a questionable WG design/location and they end up creeping to 25psi or whatever above 7000RPMs.
