Old 04-14-2010   #7
CarPsyco84
CarPsyco84's Avatar
Re: intermittion no start questions
Um, shouldn't a few more lights be on? like the CEL, coolant light and some others till the engine starts? I think the CEL light goes out when you switch from On to starting with the key, so If that doesn't happen then it is your ignition switch. Otherwise Its probably a bad connection. I fixed Alpha's car earlier this year with this problem, the bad connection melted off the wire that connects the starter motor to the solenoid
-When in doubt, Moar RPM.
