View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 05-05-2010   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Dave's Evo X Build
Initial Build Plans, rough idea:
shortblock machine work (bore / hone / resurface), shortblock assembly from bare block, cylinder head tear down / valve job / resurface / re-assembly, longblock assembly from complete shortblock, engine removal and re-installation)
Manley I Beam Rods, Wiseco Pistons (possibly wosner ones), Cosworth Bearings, OEM Head Gasket, ARP Head Studs, OEM Oil Pump, Cosworth Dual Valve Springs / Retainers, Supertech 1mm+ Valves)
Then of course we need to source a block from somewhere...and I am praying my head is ok.
The cosworth cams will be for sale too most likely...swapping them for something a bit more aggressive, probably GSC2's.
Scheides, im looking at you, want some cams
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
