Old 05-07-2010   #5
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Rewiring knock sensor, yay or nay?
I would also start with an ohm check, both threw the wire and any shorts to ground. If you were to re-wire it make sure you have a insulated casing that will shield the wire from electrical noise, tin foil wrapped around the wire with electrical tape over that then ground the tin foil on both ends to a clean chassis/engine ground. Also keep the wire as fare away from ignition and CAS and other ground wires as possible.
This.
We had to re-wire a plug back on the harness of my friend's 92 TSI so we could hook the knock sensor back up. It's been working fine so far, but I don't think re-wiring would solve phantom knock issues or an over-sensitive sensor. I have heard of using plumbers tape on the threads in an attempt to try and cushion the vibrations a bit more, however.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
