Old 06-01-2010   #5
travail
travail's Avatar
Drives: EV0 8
Re: ??? on main bearings
Based on the question this is not a major factor in the build process. In short there is NO way you could check clearance installing bearings this way. The biggest question is why you would replace main bearings with out knowing what went wrong before replacing them, and or knowing what the major specs are and if they are ok.
I was just asking if it can be done that's all. I heard that you can do it on DSM that's why I ask if it can be done on the evo 4g63.
travail is offline   Reply With Quote
