View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 06-10-2010   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I just took a look at it and it doesn't really look like it was a knock/detonation problem. The 3 other cylinders look mint, there isn't aluminum build up in the combustion chamber of the cylinder that took a shit, all the spark plugs look fine except for the one being covered in oil in the bad cylinder.
Rod bolts usually will usually break/stretch from high RPMs when the pistons pull on them on the up stroke and rods usually bend on the down/compression stroke or on the up stroke when you suck in water/blow a HG and fill the cylinder with coolant.
So you are thinking just too much torque/power for the stock rods to handle it?
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
