Old 06-20-2010   #11
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: 4g63tcrazy's new setup for 2010
Got my SMIM manifold thursday.
I got the stock one off and started modifying things to make this fit. It's a lot more of a project then I thought it would be. The first big issue I ran into was the bottom of the throttle body hit the battery, even with it lowered down on the subframe. So I had to make yet another battery trey and tie down and this is the best I could come up with.
Not as clean as how I used to have it but it works and the battery doesn't move one bit.
Then I went to bolt the throttle body on and found this..
The hole is a little too big so the throttle body cant seal. I'm thinking of just have primo fill it in a little with some welding. We'll see..
-1990 Mitsubishi Cyborg 4WD-
