Old 07-14-2010   #11
Re: Swifty's never-ending project thread!
ok, just did some research, tested a theory, and it fixed it.
When rewiring the alt to the rear, I pulled the main black alt fuse sitting at an angle on that fuse box, then re-tightened the bolts. BUT, other things also get power from that fuse, and because the fuse wasn't there to bridge that connection things didn't work, being the windows, locks, and whatever else. I went out, put the fuse back in, and instead pulled the connector with the 2 8ga. white wires on the one side, and taped that end off, but reassembled the bolts back into place, this time with the fuse in place. Now, everything works
