Old 07-18-2010   #13
CarPsyco84
CarPsyco84's Avatar
Re: Stock Boost PSI on a 199o Laser.
If you plan on running your car in the winter, might want to figure out the boost creep now... cause if its starting to creep now, it will creep alot more in the cold dense air. To the tune of 20+psi. 3" downpipe on a internal gated mitsu is bound to creep, easiest fix is a better O2 housing, that is less restrictive on the wastegated exhaust.
-When in doubt, Moar RPM.
