Old 07-21-2010   #20
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
Re: Beater 2g
The tranny should work in all years, the output shaft has the same ratio. It is the rear end and transfer case ratio that you need to match up for the year/car.
All manual 2g's have the same rear end ratios the difference is in the front diff ring gears and t-cases. The 95-96 run a 58 tooth ring gear and the 97-99 run a 57 tooth ring gear. Depending on what tranny you have you hafta get the matching t-case so that both the and rear front wheels are spinning at the same speed and not fighting each other. People have mis-matched t-cases before and burned up the VC in the tranny.
Jungy is offline   Reply With Quote
Tags
quick for a 2g, team ginger
