Old 07-31-2010   #11
Re: beaterX project thread
Alright, just went out for the first real test drive. I did a boost leak test right before I left, umm, yea. Bad idea to do that on the turbo inlet hose for some reason on the X...car was smoking so bad I was worried the turbo was blown After about 5 pulls and a few miles it cleared right up The smell of the fresh ceramic coating also threw me off, but things are cool now!
So, take this whole bit with a HUGE grain of salt, there's a LOT of caveots. The blow overlay was done on different roads so it is not a perfect example of my stock turbo setup, I think the low-end torque is over-stated compared to VDR's I've done in the past. But w/e, good enough for now. I did ABSOLUTELY ZERO TUNING and simply turned the boost up bit by bit until I saw AFR start to lean out up top. Solid 11's through the powerband and jumping to 12 at 8000rpm. 27psi peak, tapering to 25psi at 7000rpm. Currently seeing 25psi@3898rpm, so 800rpm loss in spool from the stock turbo. 100% STOCK FUEL SYSTEM!
Still, the car does not really feel aweful. It is a *bit* lazy, but with the stock o2 housing and downpipe on there, this is really NOT an ideal setup. If anyone else were to be modding their car and looking for a jump in power every few months, I'd say ABSOLUTELY do the o2 housing/downpipe first, then turbo later on. At the rate I'm going with this build, I figure I'll have that addressed before too long I left most of the heat shields and a few bolts easily accessable on the o2 housing to make the job easier when it comes time.
Now, first overlay, remember...grain of salt! No tuning! I was running 15°*of timing @7000rpm on the stock turbo, on the BBX I'm only running about 11, LOL! Def needs tuning, she's got a bit left in it!
So yea, 3000-4500rpm really suffered (remember grain of salt) which I fully expected, but 6000+ this thing just keeps going going going! Peak wtq is down only about 15, but peak whp is up around 50! With tuning I'm hoping to see a bit more than that on the current setup, but I have a set of DW800's to go in first.
Overall, I'm SUPER happy with this setup, can't wait to get a few more mods on it and see what it'll do, but moreso just continue to enjoy the car. I'm so impressed with the stock fuel system so far, I imagine I could get more out of it with more timing but idk, will that cause fuel consumption to go up and max out the injectors earlier? I can't seem to log IDC with EvoScan v2.7 so idk where I'm even at numberwise there. I'll play with it a bit more and then get some actual dyno numbers before too long.
THANK YOU CBRD!
