Old 08-09-2010   #16
Re: Camber Tires - built in 2°
Running 0* front camber would do the same thing. The way I see it, using this tire as stated and picture, is pointless.
I agree completely. 0 degrees is 0 degrees, regardless of what the wheel is doing. If the tire is flat when it's static then it's still going to want to roll in a corner, and a taller outside sidewall is only going to make that worse.
