Old 08-17-2010   #27
CarPsyco84
CarPsyco84's Avatar
Re: e85 question
Why would you need a AFPR? Only time people swap those out is when they go to a pump setup bigger than a 255LPH... And no they don't leak when you run E85 through them. I usually just run the gas tank till the lights on, and then go fill er up. You can set it first then drive it too the gas station, but it will run really rich, I doubt it would run if you don't set it then fill it up, cause it would be too lean. Ideally you just bring the laptop with and switch the setup at the gas station.
-When in doubt, Moar RPM.
