Old 09-11-2010   #11
Re: 91 Galant VR4
The car made it threw the shake down runs at Rock Falls. Due to towing issues I was late to the track but did get 2 runs in.
.069 away from the single digit club.
The first run I spun a little in 1st with a little wheel hop, 2.1 60', for the first launch with this setup I think it was ok. Then I shifted to 2nd gear at 9500rpm, and the car planted and just took off straight as an arrow, I nailed the 2/3 shift at 9500rpm and ran out 3rd before the 1/8th mile. I tapped the rev limiter before the 3/4 shift and drove it home, I had 1 hand on the wheel and the other was fist pumping with joy as I crossed the line at 9200rpm in 4th. Then the only scary part of running this fast at Rock Falls, I had to stop, in a hurry.
The 2nd run I was in the spectator lane, and they just finished track prep about 10 cars in front of me. I noticed a lot more traction in the burn out box. So I upped the launch rpm and did a little more clutch slip, 1.8 60' time, I short shifted into 2nd and then it did its thing just like the first run. And I may have lifted just a hair early to get slowed down.
The track official came over to have a talk at the end of the run, he started asking about all the safety stuff, neck brace, gloves, pants, shoes, certified chassis, etc. I said I just wanted to run fast enough first, and he said well you are fast enough, this is your one and only warning.
Then heading back to the pit the car just died, I think the aem dumped the tune and I forgot to make a copy, so I will get the tune from Shane and load it back in there.
If I can get the 60' down to a 1.4-1.5 that would put me in the mid to low 9s @148mph. For the shake down runs the car was amazing. I have video of the runs and I will try to get them up soon.
This was only the 2nd time I tried to launch the car. It is running E-85 and 38psi, the drag radials had 30psi all around. If we were able to get more runs we would have started to lower the tire pressure.
Here is the time slip, my car number was 1219:
