Old 10-18-2010   #4
Re: Proof of concept: MBC + 3port BCS Hybrid
Nice flatter line.
What happens when you bump it back up to 30psi like it was in the initial comparisons?
I will let you know once I get this piss gas I got in duluth out of my car. It runs like crap, I'm surprised I got these logs!
Originally Posted by mlomker View Post
It's no mystery that it worked...the question is what is going to happen when you fiddle with the MBC?
It's kinda cool actually. The BCS really only affects the top-end, because that is where I have any WGDC applied. From 0-5000rpm there is 0%WGDC applied. So, I upped the boost from 26/27 to 28 and it went from looking like I posted here to a more flat line (but would need just a bit more WGDC tuning to get flat again, there was a small spike to 29 at 6400rpm due to a spike in WGDC from 30-50).
I imagine once I turn the boost up to 30+ I will start to see diminishing gains and if I spike to 35 I'm sure it will still ultimately taper. For anything other than absolute max effort though, I think this setup has a lot of merit. As long as my FMIC can keep up there should be some decent gains to be had from an extra pound or two of boost up top!
