Old 10-27-2010   #4
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: Electrical short and major issue
Originally Posted by my2cent View Post
Sorry my bad.
After my alternator when bad, I had all these electrical issues.
I replaced brand new battery,Alternator,and battery terminals.
Also all bad fuses and 100a fuse.
Issue are:
Headlight comes on by itself. and it flicker
Battery will drain out in 15mins.
Horn wont stop horning ( I pulled the fuse)
No p.window
No radio
There is a draw somewhere in the car. I think its about 1.32ma
Wow, thats alot of issues. I have never seen that in a car.
The only thing i can think of for sure is on the radio. Check and see if you have constant 12 volt and ignition turn on. you gotta have both to get a radio to turn on. If you have one but not the other than there ya go. Maybe than that will lead you to something else.
As for the horn and the lights, maybe its an issue with the switch.
How did the alternator go out? Did it send a unusual high voltage output to everything? That could very well burn up relays and switchs.
