Old 01-21-2011   #8
Re: 1G Awd getting rid of that ugly hump in the trunk
2G's are easy, the gas tank is under the rear seat and there's a ton of room in the back. For the 1G, the easiest way is to cut out the hump in the tank completely, and weld a flat patch panel to it. You have to do the same for the trunk floor anyways. Remember to fill your tank with water before you start cutting it though, your eyebrows and arm hair will thank you.
