Old 03-29-2011   #14
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: 92 Galant VR-4 aka Green Colossus Demon
update!
Woot!! Currently at work right now but I'm having my brother put in the suspension and ball joints. We just replaced the driver side tie rod joints with a new one right before I left for work. Video of the horrible tie rod play will also be up soon! can't wait to start driving it! Haven't driven all winter because the tie rod and ball joint issue and now I have to find the reason why the brake and clutch fluid is leaking.
As for now, all it needs right now are:
- install KYB AGXs
- ball joint replacement
- alignment
- install the spark wires and plugs
- plug up the 2g intake pipe
- bleed the brakes and find a possible leak with the brake/clutch fluid.
- DSMLink tune
I've also got to put in the spark wires and spark plugs I got from Andrew (asshanson) before the tune. Pretty pumped for the tune! Still contemplating about moving the battery to the rear...but we'll see how it drives first.
ლ(ಠ益ಠლ)
