Go Back   MitsuStyle > The Homefront! > The Parking Lot - On & Off Topic > Video Forum
Old 04-13-2011   #14
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: EuroXport Valve Spring Compressor
Is that tool meant to hold the valve also?
No. When I use mine, I just leave the cylinder I am working on at TDC and gently lower the valve so it's resting on the piston. For reassembly you just pull the valve up and put the keepers back in with a bit of moly grease to keep 'em stuck to the valve shaft.
-Sebastian Vettel
