Old 06-04-2004   #8
john
Business as usual
john's Avatar
Thanks, I will probly end up installing ARP's this weekend. So, use loctite or not? If so, I am guessing use the blue??? Also, what headgasket should I use and what should I torwue the nuts down to? The Arp box says 80 ft. lbs (with moly lube) but this looks like a sheet they send out with every set of studs. Thanks again.
97 Viper GTS
