Old 08-16-2011   #17
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: '99 GS-T
Originally Posted by DSMINMN View Post
You know, I honestly have never met the guy. But from what I have seen not much has improved. If anything it has gotten' worse.. I don't really know how to explain it, or get into it.
I guess it is one of those things you have to experience for yourself to understand. You know?
How about you? You guys are under Adam, aren't you?
Originally Posted by Troy Rossberg View Post
Just wondering did you have the shock tower repaired or something because I see that you have black paint on it.
My eclipse is alot like yours, but i have some surface rust on the the drivers side shock tower that Im planing to repair
The "repair" was done before my dad and I recieved the car. It really is just an area they cut out what was rusting and spot welded metal in its place. Then sprayed it so it wouldn't rust as well.
I can literly see light if I put my head next to the metal and look between the welds. I would really like to pull the engine and redo the engine bay. The driver's side is starting to rust too. The car could also use a paintjob.
