Old 09-06-2011   #3
polishmafia
Smells like cat poop
polishmafia's Avatar
Re: Tire Selection Advice
Well your choices are limited unfortunately because of the staggered size and (somewhat uncommon) 19 inch rim size.
I would probably suggest that you just get a set of different rims and tires if you plan on going to the track. Maybe get a set of 18" rims with a higher sidewall tire (if they will fit over your brakes). The main reason I say this is because A) 18" tires are less expensive and B) the tires in your size are so incredibly expensive, I wouldn't waste their tread at the track.
