Old 09-07-2011   #1
dsmdion
dsmdion's Avatar
2.3l 95 TSI AWD
Hey
Selling my 2.3l TSI AWD to buy an evo9 after deciding I need to pay off engagement/wedding bills, and I want to get back into road racing, and autoX. I also want a 4 door car.
Bad
Needs a new turbo drain tube (little oil drops)
needs a middle timing cover
has a cell
has abs light on
needs shock towers finished
auto tensioner issue
Hard start occasionaly
Car has new metal welded in to fix rusting towers, but it needs some seam sealer to seal it up, and needs to be sanded and painted. The new OEM tensioner didnt want to work on the car, so it was sent back. A dif. tensioner with 40k is on it, but you'll obviously want the new one. It was sent back to MAP, and I'm waiting to here from them. The car has days where it hard starts as well. It will always start, but it has to crank for awhile which indicates an issue.
Good
Nearly everything was repalced on the engine. All new pumps, gaskets, pullys, and around 1K for Machining. I have recipts for everything as well to the best of my knowledge
Built 2.3L
OEM 2.4l crank
Manley Pistons
Manley H Beam Rods
ACL aluglide bearings
FFWD BSE Kit
ARP Main studs
Head
New Back Cut Valves
New Guides
New 3G Lifters
Forced Performance Beehive springs and retainers
Crower 413 Cams (272s, could use better cams)
Mitsu MLS Gasket
Map Standard Headstuds
Fidanza Adj, Cam gears
Gates Racing Timing belt
Zacklee Timing belt cover
Mods
14B
Apexi N1
Ebay 3" DP (had to lengthen to make fit)
Some kind of air filter
I do drive this car 100 miles a day to work and back and never had an issue other than the annoying hard starts in the morning. Body is in pretty good shape excpet for one rust spot on the drivers rear wheel well, and minor dents and scratches (like most 95s) Interior is fair, normal wear on the leather seats, has power seat button missing, and no radion. comes with a triple pod vent bezel so that big hole in the vent wont be there like in the pic lol.
Thats all I can think of for now. You can contact me at 608-797-2777. call or text, text is better either works. or dionmauss@yahoo.com. I'm ceartainly not going to give it away, but I've been in these cars for awhile, and I know they often arent worth much, the worst I can say is no for now. asking 4K OBO.
Thanks Dion.
I couldn't post any photos cause the site was being goofy, so here are some photos
http://www.facebook.com/media/set/?s...191.1208563167
dsmdion is offline   Reply With Quote
