Old 09-23-2011   #11
Re: Project XXX AWD WHP Or Bust!
Originally Posted by Alpha D View Post
hahaha! Oh man talk about FAIL ...I GET IT!!!! This for sure wont ever happen again ha!but no it wasnt on e85... pump gas...still. Im sure it wasnt from fuel in the oil. . .im positive more leaning towards some kind of mechanical failure but yeah. . . LESSON LEARNED NO MORE STOCK FPR and no more ill get that part put on once i know the car runs. . . finish 100% before turning the key got it
Just remember that when you are performing research on the internet you should validate your findings in a few places and from well respected and documented sources.
From a fuel flow perspective, overrunning the stock mas isn't the worst thing in the world, but it is still bad. It present a tuning issue when trying to calculate injector size and also makes it difficult for the computer to dial in fuel trims as two things are happening
1) The injector size is not the same as you've "published" in your dsmlink
2) The injector size changes inconsistently based on fuel consumption.
Generally speaking, new fuel setup + new components = difficult to manage unless you've been there and done that before.
Good luck next time.
