Old 09-25-2011   #7
Re: FP pump fuse keeps blowing, rewire done.
My ground is good, I'm using a stock ground on the frame. Every ground I have on the car, I've used a roloc disc to get it down to bare metal.
Its wired up just like the Vfaq says, basically stock 12v wire is used to switch on the relay and power is taken straight from the battery.
Right now we are thinking it is the stock fuel sending unit, since i had a bolt running thru where the power stud used to be, we think it could be grounding thru the unit that way. So I'm looking for a new unit instead of hacking this one further.
