Old 01-09-2012   #11
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: 4th times a charm.....
Actual miles of the car are unknown. But going by the condition, there are alot of them. lol. The dash says 60,000 which can not be true.
The body does some work, but so far while working on it, everything else looks good. Dirty as hell, but good.
I was able to scrounge up the rest of the money I needed to pick up a 5 speed ecu, 450 injectors, and matching fpr. I did need injectors, so I just took it as a chance to do this minor mod at once.
Now just gotta finish cleaning up the timing belt area, and should be able to put it back together. Just gotta order new timing pulleys. they didn't look so good.
Also found out tonight that the car has a set of Eibach Lowering springs with KYB struts on it. And they look to be in decent shape.
