Old 02-08-2012   #11
Re: Lucky #13...Back in the saddle....92 rt/tt
Updated parts list:
Current mods list on the car (and staying):
Quadco Output shaft spool
E2K t-case brace
Mitsubishi Evo 9 BOV
(few other items I will have to sell that were on last summer)
On deck/sitting at my house:
Stainless clutch line from STM (master to slave)
Shifter bushings
Deautchwerks 1000cc Injectors
Fuel Lab "mini" regulator with gauge
Deautchwerks 301 fuel pump
AEM EMS V1 (used/rebuilt)
5 bar Map sensor
GM AIT
Ebay 3" downpipe (non "F" style)
Rear 02 eliminator (ebay)
AEM dual channel wideband controller with new widebands
New dash vents (cracked ones drive me nuts)
8mm NGK plug wires
MAC Boost control solenoid
Russell AN6 Black Fuel filter
Aluminum shifter base bushings
Pioneer 6.5" TS-G1643R door speakers
BCPR7ES plugs
2-5/8" Black face, Silver Ring Stewart Warner Performance Gauges: Oil Temp, Oil pressure, Water Temp, Vac/Boost
Need to order or build prior to final assembly:
Top to bottom flowing FMIC, 2" hot side pipes, 3" cold side (E-85 will keep me cool, I want as little pressure drop as possible)
Intake setup, flirting with a bellmouth/velocity stack setup
Fabricate cat-back exhaust
Make some fuel lines.
Port some stuff.
...die 9b's die...
