Old 03-25-2012   #11
MorningWood
Drives: Evo 8, 2014 Silverado
Re: Troy's Evo
Badass!!! Glad you got it running, tuned...SD working ok for you? Any hiccups yet? Gentle reminder to keep an eye on that wideband/logs here and there as the e85 mix changes.
I love the torque of the setup man. Any idea why there's a little boost spike like that? Maybe a spring issue on the WGA? That's the only thing I'd think could be a bit better....amazing numbers on a relatively simple setup!
Spring dyno day @ DB, see you there--I want a ride!
Also, how's peak IDC%? The 1450's going to last you the summer or are you going to have to turn down the boost a little?
Not sure on the boost spike. I'll check the IDC's today, even though in Evoscan they tend to be off. I think I can make it the whole summer on the 1450's, we still had plenty of fuel so once e85 actually comes in and it needs more, there was still head room. Any more power than this and I would say i'd have to upgrade. Which is the last thing I want to do.
I'm finally happy where my car is power wise and hopefully i'm finished in that aspect before I end up turning it into an unstreetable car
MorningWood is offline   Reply With Quote
