View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 06-01-2012   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
If you have fuel pressure at the rail I don't see how that can be an issue. Can you log fuel pressure while you're driving? Even when my CTS-V had fuel issues, basically half the fuel was bleeding back into the tank and not even making it to the feed line, I could do an easy 30% throttle on E85 on a single Walbro 255 and never drop below 60psi. You would have to be starving almost all of the fuel for you to have part throttle lean issues. Either that or letting 100% of the fuel by the regulator back into the tank, but then you wouldn't be showing any fuel pressure.
Log fuel pressure while cruising. If you have just a gauge on the rail with a 1/8" NPT fitting, get a 6' section of hose with NPT fittings on the end and run the gauge into the car so you can read it. This is what I did to verify my fuel pressure was dropping under high throttle. If it is dropping, it could be the main pump getting very weak, or the regulator giving up and letting everything by.
I have one more thing to try, then checking fuel pressure in the car will be the next step I guess. One more tuning thing that is.
That is a good idea to run the hose into the cabin, thanks bud. Maybe I should just buy a fuel pressure gauge for inside the car..hmmm.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
