Old 06-06-2012   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Correct; that is the proper spring for pump gas. The other is a secondary spring that can be added for those attempting to run only high-boost.
Correct, the other one is added for 25psi, thats what MAP said.
I figured you were going to stick with that one, was just curious though as I thought you were above 25, but I agree it makes sense for the 18.
