Old 06-28-2012   #12
KROME
KROME's Avatar
Drives: Black 95 gs
Re: Gettin Medieval
For 2gs, you dont need to use a spring compressor. Im extremely confused as to why you would cut the strut, Did you use the strut after cutting it? or did you replace the strut and spring?
To get them out you simply undo the bottom bolt, slide or hammer if off of the bottom, then undo the top bolts and slide out the strut assembly. Easy as pie. You should have checked vfaq or else invested 20 bucks into a haynes guide.
Yeah. I replaced the struts and springs. Every bolt was seized. PB Blaster couldn't save most of them, several broke and several had the heads rounded over before I had the car.
I didn't want to hammer the strut off the lower bolt because I didn't want it to expand and damage anything. I ordered a Haynes months ago from Amazon but it never came in and I didn't have my laptop with me for the project. But when I looked online a while ago, people frowned upon Autozone spring compressors but bought their own.
KROME is offline   Reply With Quote
Tags
must read, smartest guy ever
