Old 07-25-2012   #2
viridionplague
Re: Need some help reading my plugs
looks like your running a bit on the leaner side of things but normal enough otherwise.
im assuming everything else is stock other than the listed mods?
the higher boost on the stock turbo tends to heat things up a lot, and if your running an automatic with the smaller stock turbo its only going to add to the heat problem.
white is leaner, black is richer, and you want a light brown ish color on the spark plugs.
