Old 12-04-2012   #11
Re: Mark's 1G Winter Projects
You are running the fuel lab 42402? They rate the flow at 13.5v (they say it will support 1200hp @ 100psi), if it didn't matter the voltage you would think they would rate the flow at 12-16v. That is the operating range they give for the pump. I would give them a call, it might save a ton of time and hassle instead of trying to put a different pump in.
