Old 12-10-2012   #20
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: 01 Stratus..starts than dies..than wont start.
Sounds like you should check your compression and your timing belt. Cause any car will run off starting fluid if the car has fuel issues. Sonuds like you need a can of gas and a match. Sit back and watch a show.
I am going to do a compression check tonight hopefully. And Maybe get it in the garage to check the timing belt again. But I am not thinking this is a fuel issue. More a spark issue. Or something not telling it when to fire.
And if I didn't want this car for a winter beater I would def just take it and have some fun. But we will see. That may still happen. lol
