Old 01-05-2013   #29
gvr4
Drives: I walk. Too many broke vehicles
Re: Piston to valve Clearance?
The best I could do was with a dial indicator on the valve retainer. I moved the crank a degree or 2, and lifted spring pressure off the lifter til I could feel the lash adjusters spring max out so I new I was at 0 lash.
I'm not sure on the block deck number, .007 was milled off the head this time, but I don't know how much has been taken off in the past.
Piston is .055 in the hole at TDC.
gvr4 is offline   Reply With Quote
