Old 07-04-2004   #2
There are usually relays in the fuse box located in the engine compartment. They should be labeled clearly, marking which are for the radiator/AC fans.
The coolant temp swich is usually mounted in the radiator, or possibly by the thermostat housing. Just a simple fitting that goes directly into the coolant and has a wire or two coming from it.
