Old 01-17-2013   #11
Re: Project Lex
Here's the numbers Kevin sent me today.
These numbers were pulled directly off of the cams you sent in:
Part Number: stock
Grind Number: 2JZ-GE
Intake Duration (gross): 240
Exhaust Duration (gross): 248
Intake Duration (.050?): 197
Exhaust Duration (.050?): 203
Intake Valve Lift*: 8.5mm
Exhaust Valve Lift*: 8.7mm
Lobe Separation: 112
Intake Valve Lash: .012"
Exhaust Valve Lash: .014"
RPM Range:
1000-5000
and here's what we're doing for yours:
Part Number: custom
Grind Number: 268F
Intake Duration (gross): 268
Exhaust Duration (gross): 268
Intake Duration (.050?): 226
Exhaust Duration (.050?): 226
Intake Valve Lift*: 9mm
Exhaust Valve Lift*: 9mm
Lobe Separation: 114
RPM Range:
2500-6500+
