Old 03-04-2013   #1
joeonegawd
Drives: 93 talon tsi awd
450hp+ 1g awd talon part out, Turbo, IM, Injectors, ect..
All parts are used and will be some what flexable in price. Car is in fond du lac. i had to move back to green bay so please be patient.
PTE6262-V-Band inlet .82 A/R with V-Band discharge $700
F38 Tial external wg $150
will post pics when i can run back to my shop
1g Head with Brian Crower dual springs and ti retainers, mild port and polish, 1mm over sized intake and exhaust valves, Kelford 272/272 cams, Fidanza Adjustable Cam Gears, and Arp stainless steel exhaust studs.
has one bad valve seal. $700
Injector dynamics 1000cc with plug and play. $350
Front mount intercooler core. $100
Tial 50mm bov. $150
ACT Maxx XtremeStreet Clutch with pressure plate. $200
3" Apexi n1 cat back. $150
Act streetlite flywheel. $125
valve cover. $50 has been blasted
Arp head studs. torqued once $50
External oil cooler setup. $125
Aeromotive 340lph fuel pump. $100
My number is 1-920-217-6391. you can tex also
Last edited by joeonegawd; 03-07-2013 at 08:47 PM.. Reason: Update as of march 7th.
joeonegawd is offline   Reply With Quote
