Old 03-18-2013   #21
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: My Newest project....
So I was able to get some more work done tonight.
I got the flywheel and clutch on. Than installed the trans after adding an OEM throwout bearing. Hopefully with that I wont have any clutch issues.
I than started to do the coolant lines on the turbo, but I gotta redo those after seeing some other peoples threads on down firing turbos. I went up and over the top of the housing with both. It may work. But I wont know till I get it all mounted up.
