Old 04-13-2013   #11
Re: beaterX project thread
Out of town for work all week but two small victories:
One, after an MRI the doctors confirm my ACL is NOT torn, just bruised knee ligaments that need time to heal. 2.5 weeks after the fall I can now mostly make it up or down a single flight of stairs without wincing in the entire way.
Two, made the haul down to MAP and picked up my (expensive) care package.
In this box is an OEM shortblock with the stock pistons/rods removed and MAP Ultimate Duty rods and Wiseco pistons installed.
Walked out and loaded up by MAP CEO Chris Carey himself--thank you sir!
I went with @murlo26 and @Knoxville to pick up murlo's new 6266 setup...thank you so much for the ride and the help guys! I can walk but I'm still a gimp.
I have to say again, MAP had this motor ready for me, start to finish, in under two weeks. The car runs and drives pretty good still but I know its only a matter of time before something bad happens. I've literally gone through 7 quarts of oil since the head rebuild in December, maybe 2000 miles ago:
Aaand all I need now is some break-in oil from O'Reily's. Got everything else I need here except a car (to drive while beaterX is down), some steaks, pizza, and beer (to bribe anyone that will help me with this swap), and some nice weather (after the spring cruise!).
Lastly, it's been mentioned to me multiple times that the spark plug failures in the 4b11 are due to a bad PCV setup as the one side goes right into the runner for cyl 1....not sure what to do about it yet but I can't ignore this since I've had two engine failures and both were in cyl1. Anyone else onboard with this? Any more discussion out there about it?
