Old 06-27-2013   #8
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: timing belt tool? is it really needed?
I always use a 90 deg snap ring pliers. And tighten it till the grenade pin can be moved in and out of the tensioner with ease. pull the pin. turn the motor oer a few times and see if you can re insert the pin. If you can its good. I havent had a belt fil yet.
11.35 @ 120mph
