View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 06-27-2013   #10
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
We run a Full Blown 340lph in Andrew's IX and it supported his 2.3L EF3 on E85 (FIC1450's), and 2.3L EF4 on 93 (FIC1050's). No silly fuel mods besides pump & injectors. It has idled perfectly on both setups so I can only assume idle base fuel pressure has been fine. I'm not sure if you can even get that pump anymore, but there is always the Aeromotive 340 which is used quite a bit down here in Evos and GT-R's as a drop-in pump.
It looks like the new AEM 320 is the same size as the wally 255. And with the install kit is only 170. maybe I will try that.
I guess from several threads I have read, people say that most of these newer pumps don't really flow more than the 255 once it has the relief modded and punched down. That was why I was considering just using that.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
