Old 07-03-2013   #21
M1L3S
M1L3S's Avatar
Drives: 99Gst
Re: 99 ecu tuning?
If you are using the stock 99 CAS it is not ajustable. If you are using a 1g CAS ground the pin on the firewall and set the timing. What have you changed since your last tune? as long as you are using the same MAS and injectors your tune should be close enuf to drive around at low boost.
I had the bottom end rebuilt.
Changed fuel pump
Changed intake manifold
And im running a 7 bolt block with a 1g head. And black cas.
M1L3S is offline   Reply With Quote
