Old 07-12-2004   #6
illz
if you're worried about fans not coming on, get under the dash and wire together ecu pins 20 and 21, then grab a switch and run a wire from the switch to ground and to 20/21. that way when the fans come on at all, they'll be on high, and you can use the switch to ground the wires manually and trigger the fans to come on high. if you want a nifty lighted switch you've gotta use a relay though, at least with the lighted switch i have it will only switch 12v, not ground, so i used the switch to trigger a spdt relay to send ground to 20/21
